How to disable fuel pump 07 NBS
I need to know if it is possible to disable the fuel pump in a 2007 NBS with a 5.3 AFM. I have already pulled the fuel pump fuse and relay, truck still runs and has correct fuel pressure.
But is the fuel pump still running...if so you didn't pull the right fuses and relays.. There can be enough fuel in the line to keep the vehicle running for several minutes at idle if the pump is off...try revving the engine once the fuse is pulled...
Yes I pulled the right fuses and relay. Had a pressure guage on the line at the time. Found out thru Alldata that the oil pressure switch also has to be unpluged.
mangomanj
Express & G-Series Vans
August 17th, 2014 9:51 PM
BRB
Silverado & Fullsize Pick-ups
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ericnottelin
13
April 13th, 2011 9:05 AM
ross_boss08
August 4th, 2008 2:41 PM
