Quit/No start-98' V6 cpi "W" vortec engine
just got(non-running) cranks well, gas at schrader valve. I poured an oz.of fuel down throttle bore-nothing but did seem to detonate/fire just as I released the key back?
I was told it needs engine and when they were driving home exiting thruway they heard motor knocking or tapping, wife mentioned tappets. They drove it home 8-10 miles and parked it where it has sat for 2 mos.
I found today resevoir empty and rad down 1 qt. or so-cold. Also rad neck appeared dry & tannish looking. engine & compartment are untouched/original has 148k miles. well that's about all I can think of right now?
Dont know if this helps, but on my 305 V-8, we had to replace the ignition module. $40.00.
Its in the distributor. Get it fired off, then listen to the tapping again. Put in fresh plugs too. The 4.3 is a string little motor, just as much punch as a 350.
Professional Mechanic
You need to find out if you are lacking spark or fuel. Just because there is gas a the schrader valve it does not mean there is enough pressure to run.
I keep thinking how they said it was clattering or knocking but drove it home?? sorry I don't have more info
I did buy an Actron fuel psi tester today but was hoping to maybe return it (unopened) to buy a better one at Amazon which has a 6' line for only 10.00 more. I figure the extra 5 ft. would be nice and maybe a neccessity at some point!
Probably outta just use it!lol. I just got it yesterday....
I would think she would fire just by even pouring some gas down the air intake thingy? what the heck to they call that again?
my distributor is probably different than yours but I don't know for sure..
dbanks17
July 9th, 2015 1:05 PM
computerdude14
Silverado & Fullsize Pick-ups
January 8th, 2013 3:33 PM
