Notices
Sponsored by: DashLynx
Quit/No start-98' V6 cpi "W" vortec engine
Old October 14th, 2009, 5:38 PM
Bill's Dad's Avatar
Default Quit/No start-98' V6 cpi "W" vortec engine
just got(non-running) cranks well, gas at schrader valve. I poured an oz.of fuel down throttle bore-nothing but did seem to detonate/fire just as I released the key back?
I was told it needs engine and when they were driving home exiting thruway they heard motor knocking or tapping, wife mentioned tappets. They drove it home 8-10 miles and parked it where it has sat for 2 mos.
I found today resevoir empty and rad down 1 qt. or so-cold. Also rad neck appeared dry & tannish looking. engine & compartment are untouched/original has 148k miles. well that's about all I can think of right now?
Old October 14th, 2009, 5:50 PM
SuperTexan's Avatar
Dont know if this helps, but on my 305 V-8, we had to replace the ignition module. $40.00.
Its in the distributor. Get it fired off, then listen to the tapping again. Put in fresh plugs too. The 4.3 is a string little motor, just as much punch as a 350.
Old October 14th, 2009, 6:33 PM
Bill's Dad's Avatar
Yes that is what I am trying to accomplish first. I did pull a plug and all looked well but do plan on going right thru it once I figure what needs to be done. I don't want to just replace the motor...unless I was to find a sweet deal. I started looking and found most people just know it's a V6 or a Vortec. I've been looking for a CPI close to year 98', I guess they call it a L35 engine. The problem is I'm not sure if it has a serious internal/mechanical problem?
Old October 14th, 2009, 6:38 PM
Professional Mechanic
MDTAHOE's Avatar
You need to find out if you are lacking spark or fuel. Just because there is gas a the schrader valve it does not mean there is enough pressure to run.
Old October 14th, 2009, 6:56 PM
Bill's Dad's Avatar
I keep thinking how they said it was clattering or knocking but drove it home?? sorry I don't have more info
I did buy an Actron fuel psi tester today but was hoping to maybe return it (unopened) to buy a better one at Amazon which has a 6' line for only 10.00 more. I figure the extra 5 ft. would be nice and maybe a neccessity at some point!
Probably outta just use it!lol. I just got it yesterday....
I would think she would fire just by even pouring some gas down the air intake thingy? what the heck to they call that again?
Old October 14th, 2009, 7:10 PM
Bill's Dad's Avatar
I should be so lucky..not
my distributor is probably different than yours but I don't know for sure..
Old October 16th, 2009, 11:35 AM
Bill's Dad's Avatar
got it going, replaced cap & rotor/primed and she fired right up! engine knocks bad though...
dbanks17
July 9th, 2015 1:05 PM
TxSheriff
April 27th, 2014 9:45 PM
computerdude14
January 8th, 2013 3:33 PM
webshot
April 19th, 2010 1:19 AM
mike688
Uplander
January 25th, 2010 12:16 PM
Quick Reply: Quit/No start-98' V6 cpi "W" vortec engine
