Electrical problems
Old Oct 17, 2010 | 12:41 PM
chase050505's Avatar
Default Electrical problems
I was changing a bulb in my 3rd brake light and something happened and it arked. Now the radio wont work or any of the reading lamps. The floor lamps and the cargo lights wont work either. I checked all of the fuses and couldnt find a bad one. The truck is a 1994 Z71.
Old Oct 17, 2010 | 12:53 PM
2wd-K5's Avatar
u have a short, may as well buy a chilons manual, or find the electrical diagram for you truck online because u have some chasing to do (but first i would check all the grounds, the easiest of whick is the stereo ground) hopefully somebody here has an electrical diagram of your truck they can scan and upload
Old Oct 17, 2010 | 1:27 PM
Once I start trying to find it how would i tell where its shorted out at
Old Oct 17, 2010 | 6:26 PM
2wd-K5's Avatar
find melted or exposed wires, and melted or exposed connectors
Old Oct 18, 2010 | 7:19 PM
ericnottelin's Avatar
You will have to determine if you have a short in the first place. A good volt meter can tell you this. You should have one hot and one ground for the third brake lamp. Use a good volt meter. Now here is the tricky thing (one of many actually . Use the meter as a voltmeter to determine if any power is going through the socket (no bulb inserted) when the power is off (brake pedal is not pushed). IE there should be no volts measure on the meter.
Now, if the meter registered something, then that will dictate your next actions.
If you have nothing without the pedal depressed, check it with someone pressing the pedal. One should be hot and one should be ground.
Let me know what the meter says, and I can kinda talk you through the next steps. Also, let me know what color the wires are that are going to the socket.
Hope this helps.
Eric
Old Oct 18, 2010 | 8:04 PM
i found it the short, it was right behind the fuse box
Old Oct 19, 2010 | 6:16 AM
Sweet, I wish they were all that easy. You need to buy a lottery ticket!!!
Old Oct 19, 2010 | 8:57 PM
If i was really lucky the motor would magicly be fixed
Old Oct 20, 2010 | 6:15 PM
Close your eyes, click your heels together three times and repeat, "there's nothing like a new engine". HAHA
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
roadtrippin
Oct 20, 2007 10:50 PM
unixmonk
Jul 17, 2006 6:10 PM
benk17
Feb 23, 2005 9:52 PM
