07' Clock issue
Old May 25th, 2011, 1:49 PM
  #11
SabrToothSqrl's Avatar
Default Keys
First click is ACC, second is run, next is start....
I could never get more than an hour in ACC w/my factory sat nav... after that, damn thing would never start.
Got an Optima Yellow Top... LOVE IT. 2-3 hours on ACC w/radio blasting. starts right up.
So, back to the original post;
DID YOU PUT A BATTERY IN IT YET?!
Old May 25th, 2011, 7:53 PM
  #12
Originally Posted by slw210
There is a TSB out there re: this issue, but I can't get to the details on what to repair. Does anyone have access or can you point me to a site? TSB is 01864, Summary:
Radio cd skips/ejects or clock resets to 12:00.
Mine is a 2003 Suburban and this applies to 2004 vehicles as well, I am surprised it is still occurring on 2007 models.
Surely there is a fix by now?
My current battery is only about 2 yrs old, it has been checked and is good. I have checked for corrosion and loose wires, even the grounds (one possible cause mentioned on some other forums).
Here are my WAGs.
Seems to me this might be a computer or radio problem. My first thought was some corrosion and cables after the battery checked out, but alas, if that is it, then I have not found the proper cable/connection.
I have noticed that from those that have mentioned it, they had the Bose 6CD units as do I.
It also seems odd that it would run from the 2003 model to the 2007, just like the gauge stepmotor problems.
Just to help everyone that doesn't believe me Put this into your search engine. "Suburban clock resets"
most TSB's will look something like this #08-03-10-004
I serached my service DVD and found no reference to clock reset or that number...
Old May 25th, 2011, 11:54 PM
  #13
Originally Posted by ousig2408
when you say KOEO position you mean with the guages and all still active? I had ours in that "position" last weekend and had music playing for over an hour with 0 issues. maybe you need a better battery?
how many other companies are using a similar charging system - if any? I really don't think the 1oz of gas it saves over a year is worth the headaches it has caused...
KOEO = key on, engine off which is basically the "Run" position so everything but the engine is active.
Old May 26th, 2011, 7:41 AM
  #14
Default lol
If your in RUN w/the engine OFF, the battery will be dead in MINUTES.
In this position the HVAC is active, the heated / cooled seats, the head lights, etc!
Old May 26th, 2011, 8:18 AM
  #15
I use the first click or the equivalent of the accessories mode, and I found that after about 20min with the radio on if you have the rear seat entertainment with the AC controls and the radio controls in the console that it gets hot! about 114degrees the front radio face gets in the 90's.... from what I can gather from turning the radio on with a charger on the battery the radio with rear seat ent. uses about 2-4amps....
Old May 26th, 2011, 8:37 AM
  #16
Default yea
yea, large drains... hence my now yellow top...
Old May 26th, 2011, 10:09 AM
  #17
slw210's Avatar
Sorry, I went straight to NHTSA and got the info this time.
Code:
Make / Models: Model/Build Years:
AM GENERAL / HUMMER 2003
CADILLAC / ESCALADE 2003-2004
CADILLAC / ESCALADE ESV 2003-2004
CADILLAC / ESCALADE EXT 2003-2004
CHEVROLET / AVALANCHE 2003-2004
CHEVROLET / EXPRESS 2003-2004
CHEVROLET / SILVERADO 2003-2004
CHEVROLET / SUBURBAN 2003-2004
CHEVROLET / TAHOE 2003-2004
GMC / DENALI 2003
GMC / SAVANA 2003-2004
GMC / SIERRA 2003-2004
GMC / SIERRA DENALI 2004
GMC / YUKON 2003-2004
GMC / YUKON XL 2003-2004
HUMMER / H2 2004
Service Bulletin Number: 01864
NHTSA Item Number: 10006615
Summary:
RADIO CD SKIPS/EJECTS OR CLOCK RESETS TO 12:00. *MR *TT
Old May 26th, 2011, 10:12 AM
  #18
slw210's Avatar
Additionally, I tried something last night and it seemed to work.
Last night I manually locked my doors with the key to prevent the security from activating, and this morning, no clock reset. First time in 4 weeks.
Here is another TSB I found on NHTSA.
Code:
BUICK / RAINIER 2004-2005
CADILLAC / ESCALADE 2003-2005
CHEVROLET / AVALANCHE 2003-2005
CHEVROLET / SUBURBAN 2003-2005
CHEVROLET / TAHOE 2003-2005
CHEVROLET / TRAILBLAZER 2002-2004
GMC / DENALI 2003
GMC / ENVOY 2002-2005
GMC / SIERRA 2003-2005
GMC / YUKON 2003-2005
HUMMER / H2 2003-2005
OLDSMOBILE / BRAVADA 2002-2004
Service Bulletin Number: 3179
NHTSA Item Number: 10010266
Summary:
AUTOMATIC DUAL ZONE HVAC BATTERY DRAW SUPPLEMENT TO 02-01-39-007A. *TT
Old May 26th, 2011, 10:26 AM
  #19
Default Nhts
that appears to not be for the 07 though...
Old May 26th, 2011, 10:31 AM
  #20
Here is what I was able to find...
File Type: pdf
Quick Reply: 07' Clock issue
