2007 Suburban Towing Mirrors
Old October 21st, 2011, 11:54 AM
bulltprf53's Avatar
Default 2007 Suburban Towing Mirrors
How can I obtain an exploded view of wide mirrors on the Suburban; or at least pop out the mirror without damage to check the problem with the power in-out drive mechanism? Any help is appreciated. Thanks. Tony
Old October 21st, 2011, 2:09 PM
I found nothing about the extended or towing mirrors but I found this procedure for removing the glass that may grant you access to the motor....
NOTE: its not a guaranty that the mirror won't get broken in the process
2007 Chevrolet Chevy Suburban - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual |
Document ID: 2173361
Outside Rearview Mirror Glass Replacement
Removal Procedure
Warning: Approved safety glasses and gloves should be worn when performing this
procedure to reduce the chance of personal injury.
Caution: When servicing electrochromic glass that is broken, or if glass breaks during
servicing, be cautious not to spill electrochromic fluid onto vehicle. Doing so will cause
damage to the vehicle.
1. Apply several layers of masking tape (1) to the mirror lower housing edge (2) to protect the
finish.
© 2011 General Motors Corporation. All rights reserved.
2. Remove the mirror lens as follows:
3. Disconnect the electrical connectors from the back of the mirror lens.
4. The motor/actuator ring (1) must stay with the motor/actuator, Not with the mirror lens (2).
2.1. Push the top center of the mirror inward.
2.2. Place your hand on the back of the mirror housing (2).
2.3. Use a suitable rigid plastic tool (3) 3.81 cm (1.5 in) wide. Insert the rigid plastic
tool (3) 3 cm (1.5 in) between the mirror lower housing edge (4) and the lower edge of
the mirror lens (5).
2.4. Lift upward on the rigid plastic tool (3) until the mirror lens (1) releases from the
motor/actuator ring.
Note: When removing the motor/actuator ring, use care Not to damage the mirror lens.
5. If the mirror motor/actuator ring (1) stays attached to mirror lens (3), the motor/actuator
ring (1) MUST be removed from the mirror lens.
Installation Procedure
5.1. Place the mirror lens face down on a soft cloth.
5.2. Remove the motor/actuator ring (1), by sliding the ring downward releasing the
tabs (2) from the back mirror lens (3).
Document ID: 2173361 Page 3 of 5
Important: If the actuator ring is on the motor/actuator go to step 3. If the actuator ring is
off do steps 1, 2.
1. Install the motor/actuator ring (1) to the actuator (2), ensure that the actuator tabs (3) are
in line with the motor/actuator ring.
2. Place the motor/actuator ring (1) in the center of the motor/actuator (2), press inward until
fully seated.
3. Connect the electrical connectors to the mirror lens.
4. Install the mirror lens as follows:
4.1. Push the lower center of the mirror motor actuator ring inward.
4.2. Position the mirror lens (1) on the mirror motor/actuator ring retaining tabs (2).
4.3. Place your hand on the back of the mirror housing (3).
Document ID: 2173361 Page 4 of 5
5. Inspect the mirror for proper operation.
4.4. Push downward using your hand on the mirror lens (1) until it is locks onto the
retaining tabs (2).
4.5. Remove the masking tape from the lower edge of the mirror housing.
Document ID: 2173361 Page 5 of 5
Old October 22nd, 2011, 7:50 PM
bulltprf53's Avatar
Thanks for the info In2Pro. Will attempt removal after carefully reading instructions.
Old April 21st, 2014, 5:56 PM
TWard's Avatar
bulltprf53, I know this thread is 2 1/2 years old, but did you ever pull your mirror and work on the components inside? What did you learn?
JoeBlow
Silverado & Fullsize Pick-ups
April 10th, 2012 9:41 PM
2008LTZ
March 20th, 2012 10:02 PM
wffokker
June 21st, 2009 3:30 PM
ronreese3
May 14th, 2009 8:41 PM
ChevyHDNutt
January 7th, 2009 8:23 PM
Quick Reply: 2007 Suburban Towing Mirrors
