95 suburban 4WD high won't engage
Old April 16th, 2012, 7:02 AM
phricard's Avatar
Default 95 suburban 4WD high won't engage
I have a 1995 suburban k2500 AT. 4WD low works OK, but high range won't engage. Actuator good, fuses OK. What's up??????
Old April 21st, 2012, 12:48 AM
noj
noj's Avatar
Had this issue on my 96, My issue was an unhooked wiring harness on the drivers side top of the transfer case (not the easiest to see) the harness had actually gotten over the case and was hanging on the back side. Made me wonder if someone helped it since I had to work to get it back to the front side to where it plugged in... anyway, After I plugged it back in I still got nothin... then hit the forums and found a post that said to disconnect your battery for 30 minutes to allow the electronics (computer) to reset. Once I did this and reconnected the battery, bingo, 4hi worked as it should. Worth reseting the radio stations for sure. Hope this helps.
Old April 21st, 2012, 12:37 PM
blueinterceptor's Avatar
actuator could be bad
Junkin8ez
Silverado & Fullsize Pick-ups
January 25th, 2015 2:33 PM
Rmatt34
December 29th, 2012 7:25 PM
grnmudz71
June 17th, 2010 7:44 PM
cjb3303
February 21st, 2010 7:31 PM
swademaster
December 16th, 2007 10:11 PM
Quick Reply: 95 suburban 4WD high won't engage
