4x4 problem
4x4 problem
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
I have a 2002 Z71 and now when I switch to 4wd, the service 4WD light comes on and I can not switch back to 2wd without turning the Tahoe off. When I start it back up, I can then switch back to 2wd. Can suggests on the problem and possible solutions?
4x4 problem
Chevrolet has had problems with the four-wheel drive switch. You might try replacing the switch to see if that will fix it. Switch is relativly cheap from the dealer
technicauto
May 4th, 2011 5:14 PM
99silver
Silverado & Fullsize Pick-ups
February 2nd, 2008 4:14 PM
cowboyfromhell
June 5th, 2007 9:31 AM
