Air Bag Light
Air Bag Light
I could use some help please, My 2005 Chevy Suburban 1500 ls 4wd air bag light came on the other day. At the same time my rear entertainment TV screen will not work(no power to it at all.) I have already look at the wiring under the front seats and they look O.K. If anyone has any suggestions I would greatly appreciate it.
Brfd
Brfd
The airbag light could be due to one of the front airbag sensors going bad. I had this happen to me a couple of years ago. Replaced it and all was good again. As far as your other issue, it might not be related to your airbag light but something else entirely. Hope this helps.
Brfd
Brfd
I had vehicle scaned by a friend and the only codes were c0035 and co455, doesd anyone know if these codes could be causing the airbag light to come on. Thank you
C0035 is a wheel speed sensor fault. C0455 is a steering wheel position sensor fault. Are you certain it's your airbag light? If it's the ABS light that would make sense as far as the C0035 fault goes.
Air bag light
Brfd
Brfd
Thank you all for your help
I got lucky, the first sensor I change was the bad one. The light went out and everything is O.K. I want to thank everyone for the help!
Foxxtrot
May 15th, 2015 1:03 PM
