Air Bag Light
Old Aug 31, 2014 | 5:02 PM
brfd777's Avatar
Default Air Bag Light
I could use some help please, My 2005 Chevy Suburban 1500 ls 4wd air bag light came on the other day. At the same time my rear entertainment TV screen will not work(no power to it at all.) I have already look at the wiring under the front seats and they look O.K. If anyone has any suggestions I would greatly appreciate it.
Brfd
Old Aug 31, 2014 | 5:31 PM
Welcome to the forum...
I'd suggest to check all fuses both in the IP side panel and under the hood...
Old Sep 2, 2014 | 8:31 AM
brfd777's Avatar
I checked fuses, all are O.k any other sugguestions Thank nYou
Old Sep 3, 2014 | 7:14 AM
titantn24's Avatar
The airbag light could be due to one of the front airbag sensors going bad. I had this happen to me a couple of years ago. Replaced it and all was good again. As far as your other issue, it might not be related to your airbag light but something else entirely. Hope this helps.
Old Sep 5, 2014 | 12:25 PM
brfd777's Avatar
Brfd
I had vehicle scaned by a friend and the only codes were c0035 and co455, doesd anyone know if these codes could be causing the airbag light to come on. Thank you
Old Sep 5, 2014 | 2:30 PM
titantn24's Avatar
C0035 is a wheel speed sensor fault. C0455 is a steering wheel position sensor fault. Are you certain it's your airbag light? If it's the ABS light that would make sense as far as the C0035 fault goes.
Old Sep 9, 2014 | 9:54 AM
brfd777's Avatar
Default Air bag light
Brfd
I think I will get a sensor and replace the front ones one at a time to see if that's were my problem lies, if that does not work I will take it to the dealer.
Thank you all for your help
Old Sep 17, 2014 | 8:29 AM
brfd777's Avatar
I got lucky, the first sensor I change was the bad one. The light went out and everything is O.K. I want to thank everyone for the help!
Old Sep 17, 2014 | 6:29 PM
Thank you for following up on your fix its what makes the forums work
Foxxtrot
May 15, 2015 1:03 PM
Chevylover247
Jan 15, 2009 5:38 PM
speedmaster
Jun 30, 2008 4:58 PM
cbr600rrnut
Jan 28, 2008 5:28 AM
skeeter13
Dec 11, 2007 9:43 PM
