beeping sound
Guest
Posts: n/a
beeping sound
Anyone ever hear 5 quick beeps (not the door chimes) when they first get in the car and turn the key to acc? I sometimes get this, but it doesn't happen all the time. There are never any messages and I can't figure out what the car is trying to tell me.
RE: beeping sound
I have never experienced such with my GMC seat belt. I have known similar thing with a Mustang model which had an annoying seat belt sound. It happens when you don't fasten your seat belt. The car beeps for like a minute or two continously and repeats up to 5-6 minutes. It's a safety precaution but maybe too annoying.
RE: beeping sound
My Tahoe sometimes makes a single beep just when I shut if off - but only in my garage. Same sound as the backup alarm but I don't shift to reverse, from D right to park.
I've just learned to ignore it - but I would sure like to know what it's trying to tell me.
RE: beeping sound
ORIGINAL: fredster
just my $0.02.
RE: beeping sound
Dave,
Do the 5 beeps make the same sound as if you hit the door lock button when "Delayed Locking" is on?
Fred,
Do you have the "Easy Exit Seat" Feature Enabled in the DIC Vehicle Customization Menu?
Fred,
Guest
Posts: n/a
RE: beeping sound
ORIGINAL: ZX1100F1
Dave,
Dave,
PS. It does sound like when you set your memory seat position, only the beep happens 5 quick times.
RE: beeping sound
The two style of beeps are different.
Also check to see if it still beeps if you go into the DIC and select "Chime Volume" Off.
Let me know and I'll see if we can't get to the bottom of this.
Guest
Posts: n/a
RE: beeping sound
ZX, I tried the delayed locking, and you're right the beeps are different. I haven't been able to re-produce the beeps after it happened twice in about a weeks time (that's why I never asked the dealership about them). So I'm not sure if I can test turning the chime volume off like you stated cause I have no way of re-producing the beeps. I may be confused however, when you say "check to see if it still beeps if you go into the DIC and select "Chime Volume" Off", you are talking about the 5 beeps I hear and not the delayed locking beeps correct?
Thanks for the help on this.
