beeping sound
Old Apr 18, 2007 | 1:21 PM
davemec
Guest
Posts: n/a
Default beeping sound
Anyone ever hear 5 quick beeps (not the door chimes) when they first get in the car and turn the key to acc? I sometimes get this, but it doesn't happen all the time. There are never any messages and I can't figure out what the car is trying to tell me.
Old Apr 18, 2007 | 1:56 PM
dzonen's Avatar
Default RE: beeping sound
Might be the seat beltbeeps. Happens to me too.
Old Apr 18, 2007 | 2:33 PM
davemec
Guest
Posts: n/a
Thanks. I get the seat belt chimes, but they are different than these other beeps. These are 5 quick beeps like the single beep sound when you set the memory seats, not like the chime sound from leaving the door open.
Old Jun 12, 2007 | 4:15 AM
postnobill's Avatar
I have never experienced such with my GMC seat belt. I have known similar thing with a Mustang model which had an annoying seat belt sound. It happens when you don't fasten your seat belt. The car beeps for like a minute or two continously and repeats up to 5-6 minutes. It's a safety precaution but maybe too annoying.
Old Jun 14, 2007 | 11:19 AM
fredster's Avatar
My Tahoe sometimes makes a single beep just when I shut if off - but only in my garage. Same sound as the backup alarm but I don't shift to reverse, from D right to park.
I've just learned to ignore it - but I would sure like to know what it's trying to tell me.
Old Jun 14, 2007 | 2:31 PM
sm3earl's Avatar
ORIGINAL: fredster
Well since you have to go through reverse to get into parkso it might beap once,
just my $0.02.
Old Jun 14, 2007 | 3:19 PM
ZX1100F1's Avatar
Dave,
Do the 5 beeps make the same sound as if you hit the door lock button when "Delayed Locking" is on?
Fred,
Do you have the "Easy Exit Seat" Feature Enabled in the DIC Vehicle Customization Menu?
Old Jun 14, 2007 | 4:00 PM
davemec
Guest
Posts: n/a
ORIGINAL: ZX1100F1
Dave,
ZX, I'll check tonight, I don't remember right now what the "Delayed Locking" sound actually sounds like. I will let you know if they are the same. Thanks for the help.
PS. It does sound like when you set your memory seat position, only the beep happens 5 quick times.
Old Jun 14, 2007 | 4:42 PM
ZX1100F1's Avatar
The two style of beeps are different.
Also check to see if it still beeps if you go into the DIC and select "Chime Volume" Off.
Let me know and I'll see if we can't get to the bottom of this.
Old Jun 15, 2007 | 8:03 AM
davemec
Guest
Posts: n/a
ZX, I tried the delayed locking, and you're right the beeps are different. I haven't been able to re-produce the beeps after it happened twice in about a weeks time (that's why I never asked the dealership about them). So I'm not sure if I can test turning the chime volume off like you stated cause I have no way of re-producing the beeps. I may be confused however, when you say "check to see if it still beeps if you go into the DIC and select "Chime Volume" Off", you are talking about the 5 beeps I hear and not the delayed locking beeps correct?
Thanks for the help on this.
