beeping sound
Old Jun 15, 2007 | 10:45 AM
  #11
ZX1100F1's Avatar
Default RE: beeping sound
That is correct, I want to know if the 5 beeps are still there after you turn the chime volume to off.
I'm trying to isolate what circuit is generating the beeps.
Old Jun 15, 2007 | 12:13 PM
  #12
davemec
Guest
Posts: n/a
Thanks, I'll try turning the chimes off, and see if I hear the 5 beeps again.
Old Jun 18, 2007 | 8:39 AM
  #13
davemec
Guest
Posts: n/a
Dave,
I tried to turn the Chime Volume off, but I only had the choices No Change, Loud and Normal. I have it at Loud currently cause they are hard to hear. Is there another way to turn these off?
Old Dec 29, 2017 | 8:11 PM
  #14
Will1968's Avatar
Originally Posted by davemec
ZX, I tried the delayed locking, and you're right the beeps are different. I haven't been able to re-produce the beeps after it happened twice in about a weeks time (that's why I never asked the dealership about them). So I'm not sure if I can test turning the chime volume off like you stated cause I have no way of re-producing the beeps. I may be confused however, when you say "check to see if it still beeps if you go into the DIC and select "Chime Volume" Off", you are talking about the 5 beeps I hear and not the delayed locking beeps correct?
Thanks for the help on this.
It could be a low battery warning.
Old Aug 24, 2020 | 8:52 AM
  #15
Barbara Porter Hutson's Avatar
Default Sequential Beeping
I had this problem in my 2005 Chevrolet Classic. Eventually, it drained my battery. I found out the wiring in the door was shorting out and draining the battery, but the beeping is what made me start looking. Once I found the short and fixed it, the beeping stopped and the battery stopped draining. Here is is, three years later and the beeping is back. I discovered the power door lock on the driver's side has gone bad and needs replacing.
Old Jan 16, 2022 | 9:10 PM
  #16
Cookie2005's Avatar
​​​​​​ It is the oil pressure gauge on mine. It will flop from normal oil pressure to flat-lining. Beep drives me nuts, Is worse on uneven roads. Flat straight roads rock my world lately since the beep is less intrusive.
Old Jan 16, 2022 | 9:16 PM
  #17
Cookie2005's Avatar
I also dropped a second battery in since I have an inverter for my oxygen machine.
kevin_cook887
Nov 10, 2024 12:31 AM
southernfryedyankee
Mar 3, 2016 12:06 PM
Proud83ElCaminoOwner
Chevelle & El Camino
Jan 1, 2014 10:52 PM
hamlet6
Feb 9, 2011 5:21 PM
adam07impala
Oct 12, 2007 1:27 PM
