Old August 10th, 2015, 11:23 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Dome light help....Please!!!
Old June 16th, 2011, 8:42 PM
  #21
Joe477's Avatar
Originally Posted by 73shark
That's why I changed my post count per page to 20.
Joe477: By chance, did they tell you how the short occurred in the first place?
They weren't quite sure. They said it looked like someone was messing around with the wires, maybe to find a power source for an aftermarket accessory. They said the wires weren't properly replaced. The only thing I could think of was there could have been an aftermarket DVD player there at some point.
Old June 17th, 2011, 12:14 AM
  #22
QUETRANPA's Avatar
Originally Posted by la perrona
im having the same problem with my dome lights did u ever get the problem solved and what did u do or what had to be done to ur truck please help its driving me crazy
hey perrona welcome to the forum!!!
what kind of truck do you have?
any aftermarket stuff installed on it?
edit: darn that 3rd page got me!!!!!!!!!!!!!!
Old June 17th, 2011, 8:54 AM
  #23
Official GM Rep
la perrona,
Did you happen to take your vehicle into the dealership to confirm if it was the BCM?
Thank you
Elizabeth, Chevrolet Customer Service
Old June 18th, 2011, 11:20 AM
  #24
la perrona's Avatar
hello uetranpa
I have a 2007 suburban 1500 its black with 5% tint all around its a nice truck and i dint end up going to the dealer to get it fixed its bad enough paying 4.60 a gallon of gas i just took of the fuse and i can still use the lights with the dimmer switch and when the doors open they still turn off i just cant turn them on individualy with their button
Old June 21st, 2011, 12:54 AM
  #25
QUETRANPA's Avatar
hello uetranpa
you know I don't use the interior lights that much, I turn them on manually if I'm looking for something at night, so when I saw the op fricking out about his problem and complaining about the free service we get on here I just couldn't believe it, but I'm glad to see that someone is thinking inside the fuse box and be ok with it
by the way looks like you have a nice truck but paying $4.60 a gal of gas!!! where are you located at? so that I know I will not move there.
saludos
Old June 21st, 2011, 5:12 PM
  #26
Would the interior lite dimmer shut the lites off?
Old January 18th, 2016, 5:32 PM
  #27
jerrybee57's Avatar
Default chevy dome light stays on
If the dash light dimmer is all the way on (at its brightest ), the dome & interior lights stay on.
Old January 19th, 2016, 1:56 PM
  #28
QUETRANPA's Avatar
Yes but they will turn off automatically after 10 minutes to save battery
Old January 21st, 2016, 8:13 PM
  #29
BMoTahoe's Avatar
Sounds like it's just the push switch for that particular light. The override only turns off the lights when a door is opened.
Old March 17th, 2021, 11:08 AM
  #30
Ozzlynn Langford's Avatar
Default Check the relay
Check the relay QUOTE=Joe477;181995]Well, here's an update. I found that there are two fuses that control the interior lighting. One is for the dome lights that come on when you open the door. The other is for the "map" or courtsey lights that you push the button to turn on. I removed the fuse for the "map/courtsey" light fuse and now the lights dim out when I close the door and come on when I open the door as they should. The issue I have now is since I removed the map/courtsey light fuse they don't turn on when the button is pushed, of course. This leads me to believe it is not a door/dome light issue but an issue with the map/courtsey lights coming on and staying on. Any ideas? Will someone post something so I don't feel like I'm talking to my self here????[/QUOTE]
96DieselBurb
January 4th, 2023 4:44 PM
Typerod
February 9th, 2016 3:50 PM
Thacker1221
2014 - 2018 (GMT-K2)
December 19th, 2015 4:22 PM
JD67
Silverado & Fullsize Pick-ups
January 19th, 2014 4:25 PM
ukrkoz
September 21st, 2009 12:43 PM
Quick Reply: Dome light help....Please!!!
