install of aftermarket radio but want to keep the rear dvd
Old April 25th, 2007, 10:54 PM
didithepest's Avatar
Default install of aftermarket radio but want to keep the rear dvd
thanks for all the help you guys , but before i go ahead with this , i need to know the facts so i can take it to my install guy so he wont hack the scit out of the truck. i havent taken the diagram i got from gm geek ( thanks man) yet . but i just want to cover mt bases
i will be replacing the head unit with a pionner z2 using the new pac adapter to be able to retain the factory chimes and onstar. my question is i need to keep the rear dvd , the rear dvd does not have the av in ( it has the factory harnes ) i need to make and adapter for it. can you help.
Old April 28th, 2007, 9:48 PM
Jarhead's Avatar
Default RE: install of aftermarket radio but want to keep the rear dvd
Just installedthe Pioneer D3 inmy 07 Tahoe with the PAC OS3-BOSE and PACSWI-PS. I also wish to retain my rear factory dvd monitor. HELP!
Old April 29th, 2007, 2:52 AM
ockevin's Avatar
you guys need GM Geek for the magic info.
Here is his website...
http://cadillacintegration.com/
Old April 29th, 2007, 11:02 AM
ock, thanks for the great help, can you explain how your install guy did it. which line he spliced or better yet pictures
Old April 29th, 2007, 12:50 PM
Jarhead's Avatar
thanks ockevin & didthepest for the diagramsbut as far as the connections from monitor to newHU - is it an oem adapter orsplicing
Old April 29th, 2007, 12:55 PM
Jarhead's Avatar
GM GEEK HELP
we have diagrams but need HELP on the actual wiring
Old April 29th, 2007, 4:56 PM
gm_geek's Avatar
http://gmgeek.com/files/2007_C3_video_connector.pdf
http://gmgeek.com/files/2007_Chevy_G...schematics.pdf
there is a little trick to it
right after you disconnect your factory radio, you'll loose power to infrared module, which is located in your overhead screen.
so what you'll need to do is, remove RSA module (behined your center console). You'll see 2 connectors, gray and green. on your gray connector, locate pink wire (pin#14) and connect switched 12 volt FUSED power to it. so that way you'll still able to use factory headphones. audio signals for infrared module are located at gray plug behined radio. I'm sure by looking at diagramm you already figured that out
also, read this thread
http://www.chevyavalanchefanclub.com...98810.html#new
for those who can't read schematics, let me know and I'll translate it for You. that.s not a problem
Old November 26th, 2016, 12:07 PM
Dave Reimer's Avatar
Default 2013 Gmc Accadia I can't seam to get my back wirless head phones to work
Originally Posted by gm_geek
gmgeek.com - gm geek Resources and Information.
Rear Seat Audio Controls w/Aftermarket HU & PAC OS-3BOSE
accadia
steeler58
Equinox
12
December 7th, 2018 12:26 PM
the struggle
January 13th, 2015 3:01 PM
sbc_421
October 7th, 2013 12:44 AM
haidangwa
January 17th, 2007 9:16 PM
Quick Reply: install of aftermarket radio but want to keep the rear dvd
