2004 Venture towing.....
Hi everyone,
I have a 2004 venture and I was curious about the towing capacities. I know the capacity says around 3500 lbs but I just want some people's personal input on my case.......I have a bass boat weighing around 1500 lbs and I need to launch and retrieve it. Do you think this will cause me trouble and I will not be able to retrieve the boat?? Thanks for your time
I have a Class III hitch on my 2002, and it's pulled anything and everything that I've hooked up behind it with no trouble @ all. Just make sure you have everything serviced and watch your temp and transmission, as you haven't said where you are (so terrain might be a factor, as I'm in a flat area)...
Nyron
Silverado & Fullsize Pick-ups
June 28th, 2010 10:55 AM
