1990 5.7 350 “knocking” under acceleration or load
Old Jan 22, 2024 | 6:08 PM
Jperez's Avatar
Default 1990 5.7 350 “knocking” under acceleration or load
Hello,
I have a 1990 Chevy K1500 5.7 350. A few months ago the truck started making a “knocking” noise ONLY UNDER LOAD. When I’m not giving it too much gas it won’t make a noise but when I’m getting up to highway speed it’ll constantly make the noise. If I’m cruising around 50-60 mph it will also knock constantly. It also runs rough at idle.
I have replaced the EGR valve twice, the EGR solenoid, the small hose between the valve and the solenoid, all the spark plugs, I have checked the time the timing is spot on, drained the oil (no glitter)/ replaced the oil, new o2 sensor, replaced a couple vacuum hoses that had small cracks and ran a tank or sea foam to try and clean anything out.
im currently at a loss and dont know what to try next. Any advise or anyone have this same problem with a fix?? Thanks in advance!
Old Jan 27, 2024 | 8:48 AM
Gumby22's Avatar
What you’re describing sound's like spark knock - if the noise has a kind of ping or bell type tone, that’s the most likely cause.
First make sure you’re using the correct octane rated fuel - 87 or 89 octane should work - if the fuel is outside the correct rating, the ECM may be unable to compensate for it.
The knock sensor is located down by the starter - some engines did have a 2nd sensor on the opposite side of the block.
Key on, engine off, unplug the sensor and check for 4.5-5.5 volt reference from the ECM. If it’s there, replace the sensor making sure not to over-tighten it. Note that some of these sensors doubled as block plugs for the coolant passages, so be prepared to catch some fluid.
Old Jan 27, 2024 | 6:53 PM
well it's an old old truck. The cylinders might be full of deposits, or the chain is stretched. Have you looked at the spark plugs?
Marty666
Jul 10, 2016 5:18 PM
oaxaca
Mar 16, 2016 11:35 PM
suzuki-guy
Apr 1, 2009 7:14 PM
cardiffcruiser78
Dec 2, 2008 7:47 PM
Andrew_350
Sep 10, 2006 12:03 PM
