1991 5.7l rusty distributor
Old Jan 14, 2019 | 9:09 PM
Rhensonsr's Avatar
Question 1991 5.7l rusty distributor
My son's truck set up 3 years while he was deployed overseas. Now it will not start. Under the rotor cap, there was a lot of corrosion so we replaced the cap and button. The truck started for 5 seconds and then died. The rusted plate under the button has chipped off so I was wondering if there is a way to check that part?
Thanks,
Randel
Old Jan 15, 2019 | 1:57 AM
oilcanhenry's Avatar
Might be simpler to buy a good used unit rather then repair this one. I assume the button you speak of is the rotor. The plate the cap attaches to is not worth replacing.
Old Jan 15, 2019 | 7:42 AM
The pickup coil in the distributor may be bad. The ignition coil may also be bad. Check out this link.
https://www.rockauto.com/en/catalog/...stributor,7108
Old Jan 15, 2019 | 2:50 PM
kevinkpk's Avatar
Pickup coil X2, and those are a *&^%$%^&* to replace!
Old Jan 15, 2019 | 4:07 PM
Rednucleus's Avatar
New gas or original 3 yr old stuff?
