1993 transmission cooler lines
Old Sep 9, 2017 | 10:50 AM
elleonlp's Avatar
Unhappy 1993 transmission cooler lines
I need to replace my trans cooler lines and am looking for a little help. Do I need to drop the tranny, or is there a way to access the lines on the trans without? any help will be greatly appreciated, I am doing this at the job site, not home. Thank You
Old Sep 9, 2017 | 4:00 PM
On both ends of the transmission cooler lines there are fittings that can be unscrewed to remove them easily.
Old Sep 11, 2017 | 6:18 PM
elleonlp's Avatar
Angry
Thank You, It was a bit of a struggle, but I did get them. The local auto parts tried to sell me lines with quik disconnect fittings, and they were Oil Cooler lines. Ha.
Now I am chasing a starting issue, turn the key and sounds like the battery is discharged, but it has a full charge. I checked every ground I can see and touch.
It will start if there is a jumper pack hooked up or another vehicle.
Frustrated.
Again thanks for you help, if ya have any clue let me know.
Tomorrow will be another day of testing.
Thanks.
Old Sep 11, 2017 | 8:25 PM
burnhedge's Avatar
Frustrated.
Thanks.
Battery needs to be load tested if you haven't already.
