1994 c2500 7.2l uca travel problem
Old Nov 15, 2023 | 4:57 PM
94c25007.2's Avatar
Default 1994 c2500 7.2l uca travel problem
Hello all,
1994 c2500
rwd
7.2 L
add-a-leaf in rear ~2” lift
front coil spacer providing 3” of front lift.
Stock length struts in front and rear.
When I roll over a tall speedbump with my front tires, rather than compressing the front struts, the whole front of the truck “jumps” up and I can hear the upper control arms dropping and smacking the shock tower at “full travel”. I.e. if i raised the front of the truck with a jack, at my “longest travel” point is where the uca is contacting the shock tower. The guy who had the truck last put the 1.5 in coil spacer in (for 3in lift) and said he never got longer struts. but i fail to see how longer struts would prevent this from occurring. there is also very limited after market support for these specific trucks being rwd. my ultimate goal is fabbing some sort of long travel myself but am at no level to do that right now. any help to stop this/ get some more front travel would be great. Im going to start with longer struts in the front- Bilstein 5100 24-186940.
thank you.
in the photo the shiny knick on the outside of the tower is where the uca contacts when the front tires are in the air.
Old Nov 24, 2023 | 11:39 AM
Gumby22's Avatar
If you’re still needing an answer….
Has the alignment been checked/adjusted since the lift kit was installed?
In the first picture, with the wheel on the ground, it looks like the camber is off and the tire is leaning too far inward. If that’s the case, the suspension isn’t moving properly during jounce/rebound and that could be why there’s lack of compression and contact between the UCA and tower.
Longer shocks should be installed to accommodate the lift, but first make sure the alignment is correct.
Old Oct 10, 2024 | 6:17 PM
karyking29's Avatar
I was recently planning a trip to Kuta and came across a useful article on OnBali. It details the best Kuta attractions such as beaches, markets and nightlife. Thanks to this information, I made a great itinerary and visited all the most interesting places. I highly recommend this guide to anyone who wants to discover Kuta at its best!
Christopher FENTON
May 29, 2020 12:57 AM
jarr
Jan 26, 2011 12:40 PM
ADVAstro
Astro DIY and Useful Threads
16
Jun 28, 2010 6:28 PM
