1994 Chevrolet Silverado K1500 5.7 NO spark !!!
Old Apr 21, 2022 | 7:48 AM
  #11
Rinconjoe's Avatar
Originally Posted by kevinkpk
One quick review on your distributor, was the pickup coil already installed? There is a heat insulator paste that needs to be applied to the coil base else it will get hot, and cause issues.
yes it was all attached already in one package
Old Apr 28, 2022 | 11:21 AM
  #12
Birdman01's Avatar
Did you get your truck going already or are you still working on it? Just wondering.
Old Apr 29, 2022 | 2:10 PM
  #13
Rinconjoe's Avatar
I too point ready burn the dam truck
i tired just replacing everything !!
ingnition wires
cap &rotor
spark plugs
ignition coil
control module - one on distributor
last year replaced distributor with the pick up coil already attached
so how do you test pick up coil
so onlt two items i can think of is the computer and pick up coil
any suggestions ?
Old May 18, 2022 | 12:21 PM
  #14
The Heater's Avatar
Hello, sir:
Here are a couple of YouTube web links for testing your ignition coil. The first video is short and he uses an LED light he bought probably at Mouser or DigiKey. You can use a GOOD quality (more expensive Fluke or an OTC) digital multimeter instead. The 12 volt source he uses is not described but you can use a benchtop small tractor/riding mower battery or a well charged spare car battery to test the ignition coil. You can get a small riding mower battery at NAPA or other auto parts store. They come in very handy for benchtop electrical testing of 12 volt items.
The second video is more detailed and he does provide electrical values for you, probably a more useful video to be thorough in your testing.
Don't burn your truck. I know firsthand how frustrating this type of electrical problem can feel. Be patient and you will get it fixed.
Old Sep 7, 2024 | 5:43 PM
  #15
Chevychase93's Avatar
You mentioned that you replaced the coil but did you check for 12v at the pink wire at the connector on the coil? Also, go to the fuse block and check a fuse that is marked ign to make sure its not open. Keep us posted on ur progress.
So I have power to all my fuses. Also power in the one pink wire on the plug that gets plugged in 2nd but not in the first. Even if I turn in over. No power to new coil and like-new distributor. Help please
rickyralph
Oct 9, 2022 4:53 PM
Zackary Quick
Jan 4, 2014 5:20 PM
miller918
Jan 26, 2013 6:16 PM
cableguy8
Oct 27, 2012 8:07 PM
catill
Aug 30, 2010 11:07 AM
