1995 K1500 Bushing tests?
Old Nov 24, 2020 | 11:04 AM
tank1949's Avatar
Default 1995 K1500 Bushing tests?
I am replacing clutch. So, while I am waiting on parts, I wanted to test my control arm bushings and ball joints for excessive wear. What is the best and easiest way?
Old Nov 24, 2020 | 11:58 AM
Gumby22's Avatar
Bushings can be checked with the wheels off the ground and a long (2-3 ft) prybar. Check the bushings visually for obvious defects such as tears. Use the pry bar to push/pull in all 4 directions on each bushing - they should be stiff with little give (1/8” max travel).
The lower ball joints need to be checked with the wheel off the ground and a jack stand under the steering knuckle. Rock the tire top to bottom to check play - if you can feel any play at all they need to be replaced, but first verify it’s the ball joint and not the wheel bearing by having a helper observe the knuckle for movement. The upper ball joints can be checked at the same time and in the same way.
Old Nov 24, 2020 | 1:31 PM
PNW NBS Z71's Avatar
You can use that pry bar to apply pressure under the bottom of the tire and just jounce the bar up and down and look for the ball joint play. You can also look at the bushings at the same time as well as the way @Gumby22 said. When you get the vehicle back on the ground and engine running again, have a friend move the steering wheel between 9 and 3 back and forth and watch for play at the tie rods and idler/pitman arm areas. You can also check ball joint play again this way as well as bushing play.
Old Nov 24, 2020 | 2:51 PM
tank1949's Avatar
Thanks to all! Will do!
Railroadertwo
1988 - 1998 (GMT400)
Feb 22, 2019 4:04 PM
'88k1500
Jun 13, 2014 7:38 PM
Matt_pound
May 21, 2013 10:40 PM
RRR
Jun 17, 2012 6:42 AM
asapinc
Jun 11, 2007 6:03 AM
