1995 k1500 Won't idle, hesitation
Old Nov 7, 2018 | 8:28 AM
Sam Boyer's Avatar
Default 1995 k1500 Won't idle, hesitation
I have a 1995 k1500 Silverado 5.7 180000 miles with basic power mods: air intake, long tube hedders, true dual no cats. The o2 sensor and egr codes have been lit since i did the exhaust. The truck ran fine for a year after I did the exhaust then a month ago it started idleing rough and bogged down on acceleration. I replaced the fuel filter, tps sensor, iac sensor, engine temp sensor. It didnt help. My mechanic found clogged injectors and a leaking intake gasket. He rebuilt my tbi including the regulator replaced the injectors and intake gasket. It ran fine for a week. It started dying again this time only in the rain. I replaced distributer and wires. It ran fine for 2 weeks rain and shine. My last week it started dying again, i checked the fuel pressure and it was normal. Im thinking its my ECM. Any ideas on how to test it? Any ideas on something else it could be?
Old Nov 7, 2018 | 11:02 AM
Rednucleus's Avatar
distributor ICM changed with distributor?
Old Nov 9, 2018 | 3:09 PM
Sam Boyer's Avatar
Im not sure I dont think its the ICM becuase it starts fine until it warms up. It seems to only act up in the rain, but sometimes its fine in the rain. I think someting other than distrbutor is getting wet, but what...
Old Nov 9, 2018 | 4:03 PM
Rednucleus's Avatar
ICM's are funny - they can be very intermittent; and especially prone to acting up when hot. If it hasn't been replaced I would do so; cheap and easy. I have had 3 go bad and they all had slightly different symptoms.
Old Nov 11, 2018 | 5:26 AM
Sam Boyer's Avatar
Ok will do
Old Nov 11, 2018 | 9:31 PM
taxista's Avatar
New User
Awaiting E-mail Confirmation
hello everybody i have a Chevy silverado 1997 with 147 000 miles for the las 2 winters my truck just doesn't want to run start right up after i drive it for about 5 or 10 minutes just die check engine light came on then die
the happens every time is cout when temperature is warm like 65 and up runs just fine any body have this kind of problem
