1996 k2500 pin 17, 18 burnt now no start
Old Mar 28, 2023 | 6:24 AM
Milestherat's Avatar
Default 1996 k2500 pin 17, 18 burnt now no start
I have a 1996 Silverado 2500 manual 5.7 and the white plug on the ecu fried. Pin 17 and 18 are fried. Now the truck won't start. It did before and it started cutting out and eventually died. Now it just cranks. I have no spark and can not seem to get spark back even with multiple ecu swaps. Any ideas? Pin 17 and 18 are grounds so I have tried to just ground them to get the truck to start but no progress. I also cannot find a wiring diagram for where pin 17 and 18 go to to check them, they should be grounds but with key on pin 18 seem to get power. I just want to get the truck running before I spend any real money on it. Any input would be great, thanks
​​​​​also I have a new crank sensor, new ignition module and coil
Old Apr 4, 2023 | 7:54 PM
Thanks
Old Apr 5, 2023 | 8:29 PM
Welcome to the forum. I'm moving to the truck section of the forum where you will get more views.
Old Apr 5, 2023 | 9:06 PM
Gumby22's Avatar
Those circuits are supposed to ground at point G120 on the top right of the engine, next to the throttle body.
That ground point is shared by multiple components, inside and outside the cab, including several components used for engine control and starting.
If excess voltage is present on the wires when disconnected from the VCM then there could be a short in the harness or one of the other components using that ground has shorted.
What is the voltage reading with the VCM disconnected? Keep in mind less than 0.5 volts is normal as there’s always a “residual” charge on any ground wire that’s spliced into other circuits.
Old Apr 5, 2023 | 9:10 PM
I will check tonight when I get back in the garage and get back with you.
Old Apr 7, 2023 | 7:57 AM
I might have been wrong about pin 18 getting power. The multi meter says there is no power. I must have been checking a different pin and got them confused. They both have no power going to them. I have 12v at the pink wire to the ignition module
but no spark
Old Apr 7, 2023 | 12:34 PM
Gumby22's Avatar
Just about every major engine control component relies on battery voltage with the key on.
The ignition control module, ignition coil, cam sensor, crank sensor, and fuel injectors should all have battery voltage at key on.
The ignition supply circuit for the engine is the pink wire and almost all of them receive power from the ENG and ECM fuses in the underhood fuse block.
I’ll try to get a wiring diagram posted in the next couple of days.
Chevygirl93
1988 - 1998 (GMT400)
Aug 30, 2020 2:27 PM
Firefox64
Mar 27, 2016 5:11 PM
dboutfitters
Oct 8, 2013 8:32 AM
fish2222
Jan 11, 2012 7:05 AM
Bushrat
Dec 17, 2009 12:24 AM
