1996 k3500 no start
Old Apr 3, 2022 | 12:15 AM
Jgriffin85's Avatar
Default 1996 k3500 no start
I have a 1996 k3500 7.4 vortec. I recently purchased it it has been sitting for a little while but ran a drove good. I moved it one day to work on it and it died like you cut the key off. I had a guy look at it and we figured the computer was bad because I had no power to my fuel pump past the relay, the engine is not firing and my ob2 won’t connect it has power just saying no connection. I put a computer a fuel pump,fuel pump relay,ignition module,crank shaft sensor,checked grounds and wiring best I could and checked every fuse I’m lost I’m no mechanic but I’m fairly mechanical savvy any help would be much appreciated
Old Apr 4, 2022 | 7:51 PM
oilcanhenry's Avatar
Assuming you have a good battery, you say the OBD II scan tool says "no connection"?
Old Apr 4, 2022 | 7:55 PM
Jgriffin85's Avatar
I got it back running
Old Apr 4, 2022 | 10:05 PM
Rednucleus's Avatar
Please tell us what fixed your problem! May help someone else down the road.
Old Apr 5, 2022 | 12:35 AM
Great deal, man!
NMB
Jan 8, 2018 2:58 PM
res7sllm
Jul 14, 2014 2:57 PM
95lum
Jan 21, 2013 6:10 AM
Chevyguy6
Jun 3, 2010 10:24 PM
shanepinkfloyd
Dec 29, 2007 2:25 PM
