1997 chyenne 1500, rough idle, stalling in p/r/d, chokes when I hit the gas
Old Mar 16, 2019 | 4:56 PM
Mike Lord's Avatar
Default 1997 chyenne 1500, rough idle, stalling in p/r/d, chokes when I hit the gas
http://imgur.com/gallery/PPTf5HM
for videos of the problem hanged mass air flow sensor
Changed crank shaft position sensor.
Changed throttle body sensor
Changed I a c (idle air controller).
Starts rough, idle evens out, in park or drive or reverse as soon as you hit the gas it stalls out.
Fuel pump and fuel pressure regulator where changed in fall.
We located the idle screw (see picture) and we turned it completely around slowly almost 5 times and it made no difference. We were trying to see if we could get it to not stall out.
This seems really irregular as it should only need tiny little movements
Old Mar 16, 2019 | 7:06 PM
Irish_alley's Avatar
I'm here for the party
i would recheck the fuel pressure just to eliminate that. ive even seen new pumps be bad right out of the box
Old Mar 16, 2019 | 7:12 PM
Mike Lord's Avatar
What would be the easiest way to check that? One person technique or two person?
Old Mar 17, 2019 | 6:40 AM
um a fuel pressure tester
Old Apr 29, 2019 | 4:15 AM
Kenneth Brown's Avatar
check for a clogged cat.. or muffler. you can check for back pressure in the exhaust. should never be more than 1 to 2 lbs of back pressure.
