1998 1500 Cold Start issue
Old Dec 22, 2018 | 7:16 AM
Marcus Stacks's Avatar
Default 1998 1500 Cold Start issue
I have a 1998 Chevrolet 1500. When it’s below 60 degrees it will turn over fine but will not crank. I can pour a little bit of gas in the throttle body and it cranks on the first try. When temperature warms up durning the day it will crank fine. I have changed the temperature sensor, fuel pump about a month ago (AC DELCO) and the filter about 5 months ago. I have over 60 psi of fuel pressure on the rail. Any suggestions would be greatly appreciated.
Old Dec 22, 2018 | 11:25 AM
Rednucleus's Avatar
Once you pour the gas does it continue to run on it's own?
Old Dec 22, 2018 | 4:09 PM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
I don't know if your unit uses a cold start valve that may not be working.
I see you mentioned that you replaced a temperature sensor, but there may be a separate coolant thermo-sensor which tells the PCM to enrich the fuel mixture when the vehicle is below a certain temperature.
Old Dec 22, 2018 | 4:40 PM
it does. It will run all day. Crank it as many times as you want after the first time
Old Dec 22, 2018 | 4:45 PM
i don’t think it has a cold start valve. If it does I can’t find any info on it. The coolant thermo-sensor that you’re talking about is the one that I changed. It made the most sense because something not tell the PCM that it needs more fuel because it’s cold.
Old Dec 22, 2018 | 4:50 PM
Rednucleus's Avatar
Does it try to start or absolutely no fire when cold?
Old Dec 22, 2018 | 8:19 PM
What engine do you have?
Where was the location of the switch?
Can you upload a picture of the switch you took out?
Old Dec 23, 2018 | 7:14 AM
it will just spin over. I have good fire from the plug wires.
Old Dec 23, 2018 | 7:16 AM
The engine is a 5.7 vortec. The sensor that I changed is located beside the thermostat on the intake. It has 2 wires going to it, black and white.
Old Dec 23, 2018 | 1:03 PM
Since the problem doesn't seem to have gone away so far, and with your additional information, I found this information which might be helpful, at this web address:
https://itstillruns.com/install-1993...p-8531973.html
I know it is showing information for a 1993, but it says this:
Locate the coolant temperature sensor; the location depends on which engine your 1500 pickup has. The 4.3-liter's sensor is on the right cylinder head, beneath the rear of the exhaust manifold. On the 5.0- and 5.7-liter engines, the sensor is on the right cylinder head under the exhaust manifold. On the 6.2-liter engine, the sensor is on the right cylinder head, in front of the exhaust manifold. The 7.4-liter's sensor is found in the center of the right cylinder head, above the exhaust manifold.
Here is another site that places a second switch on the driver's side of the engine.
https://www.gmt400.com/threads/are-t...tec-5-7.26214/
Here is a website with diagnostic help.
https://troubleshootmyvehicle.com/gm...-temp-sensor-1
Maybe the wire connector itself is corroded internally, so you replaced a good switch with a new switch, but the wire connectors got antifreeze on them or something. By analogy, when a table lamp goes out, and you replace the bulb, and it doesn't fix the problem, maybe the bulb was not the problem. It could be a whole lot of other things.
I had that problem on a Nissan Maxima.
keep us posted.
Did your engine light ever come on, or were you ever able to pull any codes?
