327 Engine
Old Mar 18, 2023 | 3:34 PM
Chuck's_Truck's Avatar
Default 327 Engine
I got an in on a 327 that needs rebuilt at a great deal. I want to do all the work minus machining. I want to keep a manual transmission and wanted to get some thoughts from the forum. Any other advice will be appreciated.
Old Mar 18, 2023 | 3:55 PM
david starr's Avatar
I recommend "How To Rebuild Your Small Block Chevrolet V8" by David Vizard. If you stay with the stock pistons you will need to use premium fuel. If you use low compression pistons, to allow regular, you will have a noticeable loss of horsepower.
Old Mar 18, 2023 | 3:58 PM
If it is a truck engine, you will already have low compression pistons or cylinder heads.
Old Mar 18, 2023 | 4:08 PM
It did come out of a truck.
tolikmelnikov
Aug 23, 2020 10:15 PM
dpwrr
Chevelle & El Camino
Dec 30, 2012 7:20 PM
daturkishulan
May 3, 2008 2:32 PM
