4L80E changes, Parts Compatibility
Old Apr 29, 2021 | 8:54 PM
Philip Lindquist's Avatar
Default 4L80E changes, Parts Compatibility
Hey, This is my first post to your forum, I have been using for a while but am now stumped. I have a 1991 Suburban 2500 2wc 5.7l, when my truck goes into overdrive it won't lock up. At first I changed the fluid, filter and shift solenoids. No improvement, I am in the process of changing the TCC clutch solenoid and 2 times I have received the wrong part. The parts store (Napa) says that part# ATP 1-6710 is a direct replacement. I received 2 different parts but both were the same part. Mine from 1991 is shaped a little different and from what I have read the early ones had a resistance value of 20-40 ohms, the newer version should have 10-15 ohms when working. The 2 new solenoids I have received both were right at 10 ohms. Does anyone have the correct part# for the early TCC solenoids, I'm tired of driving 45 in 3rd. Thanks in advance.
Old Apr 30, 2021 | 12:35 PM
Gumby22's Avatar
Are you sure you have a 4L80E? It could’ve been swapped by a previous owner.
The RPO sticker in the glove box should have MT1 (4L80E) or M30 (4L60E).
Do you know if the solenoid you need mounts with 2 bolts or nuts or if it’s retained by a separate clip?
mike 27
Astro
Oct 2, 2022 9:57 AM
Philip Lindquist
1988 - 1998 (GMT400)
Apr 29, 2021 8:51 PM
Tridox
Apr 1, 2019 7:42 AM
Wastehog
19
Sep 1, 2009 10:41 PM
agtkgv
May 13, 2007 3:32 AM
