4wd
Old Jan 29, 2020 | 10:15 AM
Chase Johnson's Avatar
Default 4wd
Hello all
I have a 1992 k1500 single cab 5.7 l v8
I recently had the old front drive shaft installed, bolted in front and back. But the 4wd still isn't working. Is there anything that Im missing?
All the help would be great!
Old Jan 29, 2020 | 11:36 AM
burnhedge's Avatar
If the fuse is good,the actuator on the front end is the next thing to check. Check the plug for power with the key on and shifter in 4x4. If it has power, unscrew the actuator and see if it extends. It's common for a bad actuator to blow the fuse so you'll want to keep an eye on it.
Why was the drive shaft removed?
Old Jan 29, 2020 | 11:41 AM
The truck was rebuilt so the guy didn't put it on in time before I bought it. And thank you! I'll check into that 👍
r696
Apr 8, 2017 1:28 PM
Aaron Alden
Dec 7, 2015 8:29 PM
cyras21
Feb 3, 2015 7:21 AM
shawn A
Apr 19, 2012 7:57 PM
adam
Sep 19, 2007 9:50 PM
