-89 K2500 weights
Old Feb 6, 2021 | 3:09 PM
Regency's Avatar
Default -89 K2500 weights
Hello, i'm new here and writing this from Finland. I have issue with my K2500 weights. Someone has taken sticker away from door and there is no rpo codes on glovebox. For next inspection i should have that sticker with right weights. Only number i have is VIN code. Is it possible to get those weights?
Old Feb 7, 2021 | 7:05 AM
Gumby22's Avatar
If you’re talking about the gross vehicle and axle weight ratings, check the driver door - a sticker was also placed just above the door latch that also listed those ratings.
You can also try the VIN decoder on this site - https://chevroletforum.com/forum/vindecoder.php
I haven’t used it yet but it might give you something.
Old Feb 7, 2021 | 11:48 AM
Regency's Avatar
Thank you for you answer. That sticker is taken away from door and there is no any labels that shows axle weights. That VIN didn't give those weights.
Old Feb 7, 2021 | 1:38 PM
Regency's Avatar
Vin code gives weights 7001-8000 lbs. From somewhere i need exact number for that label on door.
Old Feb 9, 2021 | 1:28 AM
Regency's Avatar
Is it possible that someone could watch that label on their trucks? Mine is K2500 long cabin and long bed. 4x4 and 6 lugs. I am curious what kind of weights there is.
Old Feb 9, 2021 | 7:46 AM
Gumby22's Avatar
Here’s a site/PDF with info on the 1989 models. Page 4 breaks down gross vehicle and axle weight ratings by body and suspension type.
https://www.gmheritagecenter.com/doc...ruck-PCK-2.pdf
cjm1973
15
Aug 14, 2019 10:14 AM
CrewCabFan
Aug 12, 2014 8:29 AM
nauticstar87
Mar 30, 2010 7:32 PM
Curaga
Jul 17, 2009 8:00 PM
516rider
16
Jun 29, 2009 11:40 AM
