89 silverado steering issue !
New pump. new box,upper a frames, new tie rods, fresh alignment... Question. Truck steers easier to right than to left ! If the pitman arm is not indexed correct. Could this be the problem or air in the pump ???
on my 02 i had a no power assist while turning one direction and full assist while turning another. turned out to be the gear box. did you replace yours trying to fix this issue or is it a new problem?
