93 GMC 1500 4.3 running a little hot after it gets off the highway...
Old Apr 1, 2020 | 6:21 PM
  #11
Gumby22's Avatar
Originally Posted by ericfx1984
1.) coolant res is good
2.) haven't checked like that, but i will tell you that it rips apart a small stick if it's idling and warm
3.) oil and trans fluid are great
4.) Lisle, yes and it works great on other errrr... other projects
Check the fan clutch as I described and see what the result is. They work on thermal principle - the hotter it is, the more “grip” it should have.
You could also try opening the hood once it’s hot and shutting off the engine - if the fan continues to spin on its own, it needs replacement.
Old Apr 2, 2020 | 8:23 AM
  #12
ericfx1984's Avatar
Originally Posted by kevinkpk
0 resistance means it is toast.
Yes I know that... that is why I replaced it with one my next door neighbor had laying around...
Old Apr 2, 2020 | 8:25 AM
  #13
ericfx1984's Avatar
yeah i get the idea, the engine hotter it gets, the more heat gets transferred to the fan clutch, the more it locks up... when it's crazy hot it should be darn near like having a solid mounted fan... when you just fire it up and it sat for 3 days in -15F weather it should have little resistance
Old Apr 2, 2020 | 8:30 AM
  #14
kevinkpk's Avatar
Did your neighbors vehicle have air conditioning? The older models, like my 70 olgs has two different fan clutch applications, and I am NOT sure about a 93.
Old Apr 2, 2020 | 9:10 AM
  #15
ericfx1984's Avatar
I never considered that... my money is on the fan/clutch
Yngbld14
1988 - 1998 (GMT400)
Oct 14, 2019 2:26 PM
Atreus21
Camaro
18
Feb 22, 2014 6:34 PM
tom5170
Jun 9, 2010 12:13 AM
tom5170
23
Mar 21, 2010 10:12 PM
samger2
12
May 18, 2009 11:47 AM
