94 chevrolet not firing HELP
Just purchased a '96 model Z71 with a 350 motor as a project. Have done lots of work on own vehicles, but not a professional mechanic.
Owner of truck said truck was running good and then it jumped time going down rd. He replaced the timing chain and both gears. Now the truck is not firing at all. He has not put all back together yet so timing chain is still easily accessible. I feel I need to check his work on the timing chain first?
Where do i need to start to make sure he installed timing chain and gears correctly? What is the firing order? How do I get to TDC on #1 cylinder?
Should dots on cam be at 6 O'clock and dot on crank at 12 O'clock?
Any help would be greatly appreciated.
OK thanks Kevin, but before pulling timing cover off, I want to figure out why it is not firing. If it is out of time, it should still fire right? just might be on the wrong cylinder. Pulled #1 plug out and turned motor over, no fire at plug. Is there anyway to test coil and module on coil? ohmmeter maybe?
