95 gmc k1500
Old Mar 22, 2022 | 8:28 AM
Robert Karpeal's Avatar
Default 95 gmc k1500
Hello,
I'm having trouble finding a part for my front right axle. It's called a thrust washer. After inserting axle from the other end it's the first part to go over the shaft and into the axle tube. I've checked Google partsgeek rock auto and local stores with no luck. Any help would be appreciated. Thanks.
Old Mar 22, 2022 | 10:58 AM
See if you see it in this link. If not go to a bearing store with the dimensions you need and they will probably have it. I have bought thrust washers from bearing stores before.
https://www.gmpartsone.com/v-1995-gm...xle--rear-axle
Old Mar 22, 2022 | 1:02 PM
Thanks oldchevyI think I got a part number from there (15588360) but it says discontinued as did the seal and bearings but those numbers came up at O'Rileys and the washer didn't. I believe there is a federal mogul in Tampa I can try thanks for that idea.
BowtieTillIDie1994
1988 - 1998 (GMT400)
14
Nov 15, 2024 5:38 PM
Donraffyy1
Cobalt
Apr 23, 2023 7:35 AM
Afazakerley
Nov 15, 2013 4:26 PM
ih1466
Jan 13, 2011 6:31 PM
NUTZ
Dec 6, 2009 8:28 PM
