95 k1500 V6 vortec Miss fire/loss of power when warm
Old Mar 5, 2024 | 10:00 PM
  #11
Rednucleus's Avatar
Dying with heat makes me think failing electrical - replace your ICM yet?
Old Mar 6, 2024 | 12:13 PM
  #12
Gumby22's Avatar
A couple other questions/suggestions:
1) Have you used a timing light to verify that the timing is correct? If so, did you make sure to unplug the ignition control circuit when checking it? If not, warm the engine to temp and verify the base timing is correct - it should be set at 0* - it helps to clean the timing marks on the balancer and color it in with white out or equivalent.
2) If yes, unplug the ignition control circuit and see how it drives. If the misfire/jerk goes away, something related to the computer controlled timing is the problem - it could be a bad sensor input or the ECU - further diag will be required.
3) If it doesn’t go away, see if the speedometer or tach movement is erratic/bouncing at the same time the misfire/jerk occurs. If yes, you’re likely looking at a crank or speed sensor depending on which gauge is displaying a change.
senter9
Mar 17, 2015 5:32 PM
magilla3249
May 7, 2011 6:17 PM
z28dragracer
Jan 22, 2011 11:27 PM
cris2for
May 6, 2010 11:18 PM
gto8u
Mar 13, 2008 10:58 PM
