96 Chevy 1500 5.7l 2x4 ext cab
Old May 28, 2019 | 4:55 PM
Todd Tegethoff's Avatar
Default 96 Chevy 1500 5.7l 2x4 ext cab
I'm having problems with A/C. I'm only getting a whisper of air coming out of the vents. Mostly coming out from defrost area when it's on any speed setting. Blower motors new, blend door is new, temp control module is new and I also cleaned the evaporator coil very good. Still only a whisper of air coming out of the vents. What's left? PLEASE HELP!! ITS TO HOT AROUND HERE.
Old May 28, 2019 | 7:11 PM
oilcanhenry's Avatar
Might be either your resistor or the relay, both behind the glove box. The resistor is a kind of a bear to get out, but you'll need a 7mm socket to remove it.
