'96 K1500 5.7 no crank after swap
Old Oct 23, 2023 | 9:52 AM
L.HarveyTeabag's Avatar
Default '96 K1500 5.7 no crank after swap
This has been a project truck for the better part of 3 years so I will attempt to keep it brief. Thanks in advance for any help/tips y'all can offer.
I bought this truck 4 years ago with a "mild misfire" that quickly went from a new cap, plugs, and wires to a full top end rebuild, valve job, ect. That engine ran briefly, then lost compression in cylinders 4 and 6. I tore the top end back off, had the heads checked by a local shop and verified the heads were holding compression properly. At that point I didn't want to dive any deeper into bottom end rebuilding, I worked in a hydraulic repair shop then a machine shop for years, but I'm not a mechanic and I know when I'm outmatched. So I picked up a verified running donor engine and swapped it out.
​​​​​*Note* I used the heads, both upper and lower intake, and water pump(new) off the old engine. I spent a boatload of time cleaning everything, putting a new spider in, gaskets, ect. So I figured why let it go to waste?
When we were lowering the engine in my dad was running the hoist and I was guiding it in. He twisted the handle the wrong way and dropped the ending about 6 inches into the bay. It pinched a couple wires, broke the distributor, and a fan blade dented the radiator but that was all I could find after inspection.
So I bolted it in, wired it up, filled fluids, fresh fuel, ect. Hit the key, all dash lights come on, fuel pump kicks, then nothing. The starter has juice, I replaced the Neutral safety switch(the connectors looked fine) and Ignition relay.
Still nothing.
​​​​​​So what would be your next move? I'm grasping at straws at this point.
-Adam
Last edited by L.HarveyTeabag; Oct 23, 2023 at 10:52 AM. Reason: Autocorrect misspelling
96k1500
Jul 14, 2021 2:00 PM
SeanOD
1988 - 1998 (GMT400)
Oct 7, 2018 9:54 PM
Matt Davidson
Jun 4, 2018 7:20 AM
MissionValley
Apr 2, 2014 1:55 PM
GoChevy
May 20, 2010 10:54 PM
