97 Chevy k1500 5.7L
Old May 7, 2023 | 11:57 PM
that704chevgirl's Avatar
Default 97 Chevy k1500 5.7L
I need some input please. Truck started overheating about a month ago and I’ve been working on it since. Changed the thermostat - no change. Changed water pump - no change, but started blowing cool air when on heat. Changed bottom radiator hose and both bypass hoses on water pump - no change. Hose running from heater core to intake manifold busted, changed that - no change. Put in a new thermostat sensor - no change. Switched and put old water pump back on, took longer to overheat and started blowing heat inside the truck. Put on a new idle air control valve - still overheating. Is there any other possible thing I could look at?
Old May 8, 2023 | 9:32 PM
oilcanhenry's Avatar
Got to make certain to get ALL the air out of the cooling system, period.
Old May 9, 2023 | 9:43 AM
we burb the hose every time we change out the coolant
Old May 9, 2023 | 10:30 AM
Birdman01's Avatar
Is there any white smoke coming out of the tailpipe? You may have a blown head gasket. Check for air bubbles in the radiator. A bad intake manifold gasket will also cause over heating. Make sure you don't have any leaking, corroded freeze/ expansion plugs in the block or heads, of course, this is obvious by doing a manual inspection. Finally, check the oil dipstick for any signs of water in the oil. You will see a milky oil if there is water in there. Just some things to check.
Aboom
1988 - 1998 (GMT400)
Nov 26, 2019 1:15 AM
Driven1990
Mar 14, 2016 7:30 PM
bugrollei
Mar 21, 2014 9:24 AM
leviathan907
Mar 12, 2012 7:31 PM
dcoperator
Jan 11, 2009 7:23 PM
