Ac idle question
Old May 25, 2020 | 8:38 AM
Adrian Blanco's Avatar
Default Ac idle question
Hi everyone, new to the forum. I have a 93 Chevy 1500 5.7 with manual transmission. Truck runs and idles great at 750 rpm but when I turn on the AC my idle will drop down to 500 rpm. Is this normal or should it maintain my 750 rpm? This sounds like something isn't right. Thanks in advance.
Old May 25, 2020 | 8:39 AM
kevinkpk's Avatar
It should not drop the rpm.
Old May 25, 2020 | 10:03 AM
Any idea why it drops?
Old May 25, 2020 | 10:50 AM
what type of fuel injection system does it use? throttle body, spider, multiport? idle speed is controlled differently depending on the build. if you have an iac valve...it should open more when the ac is turned on
Old May 25, 2020 | 11:08 AM
Tbi. It has an IAC.
Old May 25, 2020 | 11:13 AM
maybe the iac port is blocked,the iac valve is stuck or the iac is not getting power
aahamed
Feb 24, 2018 10:14 AM
JohnOH327
Jun 19, 2015 3:20 PM
burrell22
Aug 9, 2013 1:19 PM
Mldierdorff
Cobalt
Apr 25, 2013 5:49 PM
chaser
Apr 11, 2010 5:27 PM
