Notices
Aftermarket Temperature Sensor
Old January 28th, 2018, 10:49 AM
Bradley Jones's Avatar
Exclamation Aftermarket Temperature Sensor
Where is the best place to run an aftermarket temperature sensor from front of motor to inside the cab through the firewall on my 1992 Silverado??
Old January 28th, 2018, 11:06 AM
I always try not to drill any holes if at all possible. Try and push the wire through where there is an existing pack of wires without damaging the grommet. I have been able to do this the few times I tried it. If you are replacing the old sensor, use the wire from the old one.
Old January 28th, 2018, 11:09 AM
Not replacing old sensor putting aftermarket with its own cable it's got about a 5/8 adapter on the end and I haven't found anything for it to pass through. If I'm missing something let me know. Thanks
Old January 28th, 2018, 11:26 AM
You didn't say it was a mechanical gauge. That's different. You will have to drill a hole, but make sure it is in a spot with nothing else in the way and also make sure you seal it real well to keep water out.
Old January 28th, 2018, 11:30 AM
Ok that's what I was going for. Looked under over and didn't see anything. Just thought I would ask before I did it. Yes you are absolutely correct I didn't specify what type of gauge. I apologize. Thank You!
