Assumed Electrical Issue
Old Apr 1, 2016 | 9:54 PM
zachartrand's Avatar
Default Assumed Electrical Issue
Hey all,
I have a 1990 k2500
Today I was on the highway and all of a sudden my electrical went out. Everything turned off from headlights to radio. The truck acted like it had stalled. I lost power to the engine (maybe fuel pump? Maybe it had to do with the fact that I was on cruise control. I think even after I hit the pedal I was still not getting any gas though.). It happened when I hit a bump. Everything came back on after about 2 seconds, but then the same thing happened about 2 or 3 times through a span of about 30 seconds. After this I was able to make the entire 30 minute drive home with no further problems. The only thing I can think of is a ground connection. I don't where my grounds are though, and I never though just one ground could turn everything off. Any suggestions?
Old Apr 2, 2016 | 9:54 AM
battery fed fuseable links or ignition switch comes to my mind. the fault will have to be active to perform any testing to verify the problem.
Old Apr 5, 2016 | 7:38 PM
bolts66's Avatar
same thing happened to my 94. it was the fusible links located on battery cable. i just bypassed them and it was fine after that. you can try just moving battery cable around, it may start and run after that,if it does, its your fusible link.
