Bad catalytic converter?
Old Jan 23, 2022 | 2:29 AM
Jesse9657350's Avatar
Default Bad catalytic converter?
97 k1500 5.7liter
Bought the truck cheap not long ago, going over each thing one at a time. Next up is the exhaust issue.
The truck sounds like it as an aftermarket muffler, but it does not lol. It has a nice little rumble , not too loud, which is cool but I know that's an issue , possibly a hole somewhere? Plugged cat?
My check engine light ofcourse is on with a misfire on number 4. Also have a weird sulfur smell every so often
everything points to a bad cat, is there a way to fix this without spending a crap ton?? Thanks for help guys, one piece at a time !
Old Jan 23, 2022 | 9:32 AM
Basically looking for some DIY tips on fixing catalytic converters. Anyone else fixed them yourself ? What ya do?
Old Jan 23, 2022 | 9:50 AM
scotty kilmers channel has a cat Hack fix.
if you cat was plugged....it would have no power at high rpm. bypassing the cat by removing the 02 sensor is a way of checking for a clogged cat.
if the cat was not redox reacting it would set p0420 p0430 dtc.
swap #4 plug and wire with a non misfiring cylinder...see if the misfire follow the plug and wire. if it does,,,replace plug and wire. if it stays on #4 and the misfire is all the time...compression test. if the misfire is intermitent....when does it occur?
Old Jan 23, 2022 | 10:28 AM
I'll do the plug swap test today and see what happens. The misfire is consistent , I changed all the plugs a few months ago as soon as I bought it. I haven't changed the wires , rotor or cap yet. That was next ,until I realized what the cat was doing , I'm assuming it's a hole somewhere because I'm getting exhaust from both the end of the tail pipe,like normal, AND from right under the engine , around the Cat area. It could be antifreeze burning off as I did replace the water pump yesterday, fired it up this morning and had an intermittent flow of exhaust right from under the cat, it didn't do that before , so I'm guessing that's antifreeze.
I will put the code reader back on today and get a list up of all the codes, I know a few were pertaining to the cat and/or emissions, I can't remember exactly what they were but I will get them posted today. Thank you for the help Tech 2
Old Jan 23, 2022 | 10:32 AM
Follow up question, if it is the cat, and they or it needs replaced. I want to run a system with no cat, and just the stock mufflers for now. I want good power and good gas mileage on the truck ,is this the right way to go about it? I don't fully understand back pressure and all that yet, but what ya think would be the best setup for a 5.7l? I don't want it stupid loud, I want a deep rumble. Also I know a tune is probably required after cutting the cat? So the computer doesn't know the cat is gone ? I'm researching this stuff today as I don't fully understand yet. Thanks again for any help
Old Jan 23, 2022 | 2:31 PM
Default Update!
Update on the exhaust system. Threw a code reader on it, no longer a misfire , I guess the new plugs and wires took care of that. The only codes now are bank 1 and 2 for the O2 sensors. There are 4 O2 sensors total, 2 behind each cat and 2 after. With the louder exhaust sound I have, I'm assuming one of my cats is bad, I did check for leaks/holes, I couldn't find any .
I think I will cut both cats off and just run pipe to the stock muffler , and erase engine codes.. thoughts ??
Old Jan 23, 2022 | 4:41 PM
post the codes b4 you cut anything off.
if you want to find the exhaust leak....idle the engine and have a friend hold a rag over the tailpipe. this will create back pressure making the leak easier to find....feel and listen for the leak. check the manifolds for broken bolts and signs of a leak....black soot.
Old Jan 23, 2022 | 5:33 PM
Tech 2 , ok I will post codes today before I go any further.
I also have a buddy that will help with that rag test, will post updates tonight , much appreciated 👍👍👍
Old Jan 23, 2022 | 9:17 PM
Rednucleus's Avatar
Depending on where you live cat removal is illegal and I think keeps you from passing emissions; maybe no longer a problem for a '97??
Old Jan 25, 2022 | 11:44 PM
Rednucleus emissions isn't a worry in Montana , luckily lol
tech2 working on getting codes my code reader is "missing", I'll have them up soon 😎
