Bed bolts
Bed bolts
I need to remove the bed of my truck to replace the cab corners that are rusted out. I cannot find a bolt kit to replace the bed bolts. Does anyone have any idea where I can get the bolts other than just removing them and hunting them down at a hardware store. I have tried all of the truck parts websites with no luck.
You’re better off going to a hardware store anyway - any kit you find will be overpriced for what it is, even from typically cheaper websites like Amazon or eBay.
Most hardware stores will have the bolts and U-nuts in stock which also saves the hassle of shipping.
There’s 2 possible bolt sizes that were used. I can’t tell you for sure which one you have because in the early 90’s GM began transitioning all fasteners to the metric system, so they could be metric or SAE.
Either of these will work for you as they’re very close in size and have nearly identical torque specs.
SAE - Grade 8 - 3/8 x 16 x 1”
Metric - Grade 8.8 or higher - M10 x 1.5 x 25mm (or 30)
Use nickel or aluminum base anti-seize and torque to 25-30 ft-lbs
nechevy
September 13th, 2011 1:00 PM
EagleEye82
October 17th, 2009 1:25 PM
jpo138
January 8th, 2007 11:11 PM
