truck bed (not cab) leans to right side
Old Jul 2, 2020 | 3:42 AM
chrischambers's Avatar
Default truck bed (not cab) leans to right side
I’ve noticed & measured the bed of my truck & the left side sits higher than the right. I bought it from out of state so I don’t really know the history of the truck, but what could be causing this? I have a 97 Chevy C1500. attached picture below. if you look closely at the cab, you can see the right side of the bed is lower. It doesn’t look like much, but def more noticeable in person.
Old Jul 2, 2020 | 4:05 AM
Maikelo's Avatar
Well first of all be sure it's parked on a flat surface.
Most of the time it's worn-out suspension, it can give the impression that the bed is leaning but sometimes it's the cab that is leaning so be sure to check that.
Other reasons could be worn-out parts between bed and frame, accident damage, extreme overloading or wrong loading.
Old Jul 3, 2020 | 8:51 PM
alpinecrick's Avatar
Have you by any chance actually crawled under the truck and looked at the bed to frame mounts and bolts? Bring a tape measure while you make the trip under the truck. Measure from the top of the leaf spring pack to the frame on each side and compare. As Maikelo says one of the spring packs might be sagging. The bed mounts might be rusted or crushed from something really heavy being dropped in the bed. The frame may be bent from an accident.
Old Jul 3, 2020 | 9:39 PM
I haven’t gotten under it and looked, wasn’t sure what to really look for at the time. Thanks
eric wrighter
2019+ Silverado (GMT-T1)
Feb 14, 2020 4:40 AM
David Satterley
Oct 28, 2018 7:57 PM
samsaridinc1500
Jun 24, 2013 11:28 AM
glegeza
Jul 26, 2010 10:29 AM
EagleEye82
Oct 17, 2009 1:25 PM
