bottom end knock?
Old Jan 13, 2020 | 5:18 PM
JoshuaStanley84's Avatar
Default bottom end knock?
i recently rebuilt a 98 5.7 vortec, since day one it has had this bad knock (refer to video). played with valves to eliminate adjustment issues.it sounds like it is coming from the oil pan. Sometimes it will stop for a second when put in gear but comes back a little quieter. it gets either quieter or drowned out or stops when accelerating. ive checked my flex/converter bolt. all were tight with no scars and the plate looked good also. any ideas?
Old Jan 13, 2020 | 5:45 PM
video
File Type: mov
Old Jan 13, 2020 | 6:47 PM
Little Bear's Avatar
Sounds like a cracked flex plate, I had one similar, the crack was near the center so you couldn't see it until the trans was pulled.
booglemackey
Aug 30, 2016 12:49 PM
knockknock
Jun 29, 2013 12:37 PM
ireuel
May 30, 2011 10:50 PM
blackbus1
May 9, 2010 9:12 PM
s34n
Nov 15, 2009 12:10 PM
