Brake lines again...
Old Sep 2, 2022 | 9:14 PM
96 Junk That Moves's Avatar
Default Brake lines again...
I am going to replace the passenger side rear brake line on my 98 GMC 1500 4X4. What size line do I need 3/16 or 1/4 ?
Regards,
Junk
Old Sep 3, 2022 | 7:05 AM
Amazing! 78 views and not 1 reply...not even anything sarcastic...
Old Sep 3, 2022 | 7:29 AM
Measure your old lines!!
Old Sep 3, 2022 | 8:44 AM
kevinkpk's Avatar
Usually no answer is because it's not known. Given it's a truck, I'd say the larger line is what is used.
Old Sep 3, 2022 | 1:57 PM
I measured the length 40" is an aprox. length If it's a bit too long I can adjust in the bend that goes over the rear end housing. I don't want to remove the old line before hand so as not to loose too much fluid. Right now it's a slow dip, if I remove the line it will be a major leak.
Old Sep 3, 2022 | 4:35 PM
kevinkpk's Avatar
You can plug it off.
Giddyupz28
Avalanche
Sep 22, 2019 9:14 AM
dwoerman
May 24, 2015 11:32 AM
otto11
Oct 15, 2013 6:44 AM
IRISH_K10
Aug 20, 2012 10:16 PM
pwinstead
Oct 28, 2008 10:14 PM
