Climate Control update
Old Dec 21, 2021 | 6:34 PM
Jesse9657350's Avatar
Default Climate Control update
Update on previous thread,
. Climate control module has stopped working completely, no lights , none of the fan speeds work, nothing. First thing I want to do ,before buying a new module, is recheck fuses and relays , but I don't know which ones to check!? I have the diagram but there are several that seem to pertain to HVAC controls and whatnot , is the module on a fuse inside the truck? Or is it on a relay under the hood? Just would like some advice on which fuse or relay to check or replace before I drop $100 on a new module thank you
Old Dec 22, 2021 | 8:04 AM
Mr. Dude with a face's Avatar
check all the fuses. It will take all of a few minutes. If i had to guess, if it is a fuse, it will be in the fuse panel that is on the drivers side of the dash, behind the door. But, i would check the ones under the hood too.
Old Dec 22, 2021 | 5:07 PM
Working on it thanks guys
mmartin
Jan 19, 2020 3:51 PM
Tex57
1988 - 1998 (GMT400)
Feb 12, 2018 8:26 PM
Ernie Clayton
Avalanche
Mar 11, 2016 3:18 AM
MMVIII_Silverado
Jan 20, 2014 2:48 PM
Star_Coach
Jul 2, 2013 11:52 AM
