Dash gauges bouncing, Amp gauge shows discharge
Old May 21, 2018 | 3:25 PM
GeezerPete's Avatar
Default Dash gauges bouncing, Amp gauge shows discharge
I have a 1993 Chevy K1500 4x4. All of a sudden, the dash gauge needles are jumping up and down. The amp gauge shows a complete discharge all the time when running. I have tested the battery, cleaned and replaced the battery post bolts and the negative battery cable. Replaced the alternator, multi-function relay on the firewall, the ignition cap and rotor. I have also replaced the ignition switch in the steering column. All to no avail.When it's not under a load, sitting in the driveway, in park, with the engine running, it runs and sounds great. But when I drive it, it wants to stall, the ABS light flashes and the gauges needles jump erratically.
Please, what do I do now to make my Chevy dependable again?
Last edited by GeezerPete; Jun 3, 2018 at 9:46 AM. Reason: I first changed the negative cable
Old May 21, 2018 | 4:10 PM
kevinkpk's Avatar
Check, clean ground on the abs.
Old May 22, 2018 | 8:29 AM
GeezerPete's Avatar
I don't know where the ground for the ABS system is located. Can you tell me where to find it and what it is? Thank you for your help.
Old Jun 3, 2018 | 9:43 AM
GeezerPete's Avatar
I couldn't get anyone to tell me where the ABS ground is. So, I decided to replace the positive cable from the battery to the stater, didn't work. Then I pulled the dash gauges cluster and touched up the solder on the plugs. Didn't work. Has anyone ever ran into this problem before?
Old Jul 19, 2018 | 8:49 AM
Sabino56's Avatar
I had similar problem intermittently. My abs was also bad and throwing every code possible. I found a power wire which had been overheated on power distribution o firewall. I assumed an actuator or something in the abs was shorting so I removed it. I haven’t had same problem since but no direct confirmation that was the problem as it was intermittent in first place. Is the yellow abs light on? If so, I’d try unplugging the two connectors on the abs (on drivers side inner fender) and see if it goes away.
Old Jul 19, 2018 | 9:26 AM
kevinkpk's Avatar
Look under the frame, it's the largest ground wire there
