Dying while driving
Old Apr 7, 2017 | 9:31 AM
Kyler Daybell's Avatar
Default Dying while driving
My 1992 Chevy suburban 1500 dies while driving at any speed any engine temp and any rpm I can't seem to find any pattern as to when it dies there usually isn't puttering the tac just drops to nothing and all of the warnings light up I have changed the ignition switch, fuel relay, distributor control module, the distributor, the fuel filter, and the ecm. After I changed the ecm it went for about 1000 miles before dying again but sure enough it did. The check engine light comes on periodically but only stays on for five minutes before going away last time I had the codes checked it was an egr valve leak. I have dumped Tons of time and money into this truck and can't seem to fix it
​ any info is greatly appreciated.
Old Apr 10, 2017 | 10:11 AM
Jeepwalker's Avatar
Does it start right back up after it dies?
There is a pigtail wire that comes off the pos battery cable by the battery. AFAIK, it feeds the ECM ..but not sure on your year. Check the wire carefully. That might cause it to die suddenly. Otherwise, I wonder if it could be a fuel-pump plug where it goes to the tank ...corroded? Just throwing out idea here.
Old Apr 10, 2017 | 11:28 AM
Default Yes
Yeah it starts right back up after it dies usually no problem till it dies again
Old Aug 3, 2018 | 12:39 PM
phantom110's Avatar
Default Same issue
My '97 Silverado 5.7l Vortec is having the same issue. I've replaced the fuel pump relay, but still randomly dies with no warning and no lights. Starts right back up. I'm thinking it's electrical, but where do I begin?
